It doesn’t show up in the Options list…
thanks
thanks
Yes, that’s where it is - I’m asking how we remove it.
to turn it off (without uninstalling it) it should be enough to click on the icon before the name here:
if you want to remove it completely, depending on how you have installed it:
→ it could be a grasshopper .gha file you need to manually delete, in this case you can find the file inside this folder, and will be probably named Sunglasses.gha
→ if you have installed it through PackageManager
Perfect! Thanks!
Nice to be able to switch on & off.
