Hello ,
with openurbs sdk ,
how I can get the nurbs_surface definition from a SubDFace , and also the nurbs curve from a SubDEdge ?
thanks
Laurent
Hello ,
with openurbs sdk ,
thanks
Laurent
toNUrbs command, and dupedge command
Hello Dale ,
yes , I can see into opennurbs SDK :
//virtual
bool ON_SubD::HasBrepForm() const
return false;
//virtual
ON_Brep* ON_SubD::BrepForm( ON_Brep* destination_brep) const
return nullptr;
and when I use the method ,
bool ON_SubDFace::GetQuadSurface(
class ON_NurbsSurface& nurbs_surface
) const
or
class ON_BezierSurface& bezier_surface
) const
I never get the surface because I always have the same way with :
if ( false == qft.m_bIsCubicPatch )
return false;
I try with a plane and sphere transform to SubD with rhino7
with Rhino , I can export to iges-step these subd , can you tell me if you have a function into opennurbs SDK , for getting the nurbs_surface-curve definition or not ?
thanks
Laurent
No we do not, sorry.
– Dale
Hello Dale ,
as with rhino7 , you can export to step these subd , is it possible to know the algorithm that you use for getting the nurbs definition I will implement the same way ?
thanks
Laurent
Hello Dale ,
ok
thanks
Laurent
Hello Dale ,
I have another ask , for a subd , the associated graphic mesh isn’t store into the 3dm file ?
thanks
Laurent
Dear ,
I found these 2 functions for creating a mesh , but which value for count , I set 3 , is there a better default value ?
bool ON_SubD::GlobalSubdivide(unsigned int count);
ON_Mesh* ON_SubD::GetControlNetMesh(ON_Mesh* mesh, ON_SubDGetControlNetMeshPriority priority) const;
thanks
Laurent
Hi @eraud,
Just use ON_SubD::GetControlNetMesh.
ON_Mesh mesh;
subd.GetControlNetMesh(&mesh, ON_SubDGetControlNetMeshPriority::Geometry);
or
ON_Mesh* mesh = subd.GetControlNetMesh(nullptr, ON_SubDGetControlNetMeshPriority::Geometry);
if (mesh)
// todo...
delete mesh;
– Dale
Hello ,
I download the latest version :
opennurbs-7.0.20255.14200
but if I don’t use the function , bool ON_SubD::GlobalSubdivide(unsigned int count); ,
the method : GetControlNetMesh doesn’t return a good representation of the SubD
subd with white color and mesh with red color .
I suppose into Opennurbs SDK , we can’t access to the rhino function from mesh Menu with : From NurbsObject ?
thanks
Laurent
That is correct. OpenNURBS will not mesh NURBS objects.
– Dale
