Hi all. I am trying to import Substance materials into my model but they turn up as grey. Substance Importer is up to date, not sure what the issue is, some help would be appreciated.
can you attach the material you are using here so we can try to reproduce it?
Yep gray here too. I’ll write it up, looks like the substance importer is broken. All materials come in grey here.
RH-80148 Substance importer broken
Is there a way to roll back to an earlier version of Rhino so that the Substance Importer will work?
try using package manager to uninstall substance then roll the substance importer back to 2.0.3.
see if that works. If so, use package manager again and see if you can update to the latest version 2.0.5
that worked here.
2.0.5 appears to be crap… I reinstalled it again here and it greyed everything out for v7 and v8.
2.0.3 seems to be working fine. I’ll chase it with @andy and the substance folks and try and figure out what broke.
