lagouros
(ARKITECTONICS)
October 16, 2024, 7:24pm
1
Can you recommend some guides/tools/workflows for subdivision modeling edge flow tools?
Process right now is:
Points On, Draw Guidelines, Move Control Polygon Points.
Other technique is 0-Scaling based on gumbal,
SetPt.
Flow to a curve is horrible with sub-d control points… Maybe I’m not using it right…
I think if Rhino can bring the nurbs-level precision to subd, we will have a big jump in awesomeness… anyone else think so too??
Plz…Any help, recommendations and post links to this would be very helpful/useful.
Thx
BrianJ
(Brian James)
October 16, 2024, 8:08pm
2
Hi @lagouros ,
Try the Align command with SubD sub-objects selected or use the command EditPointOn and use Align with the edit points of the SubD instead. Align has a number of tools in it but two that I use often are ToFitPlane and ToCurve.
I’m not sure I understand exactly what you mean by edge flow in the context of retopology but you may want to use guide curves within the QuadRemesh command.
Please post any specific questions with example files for more help.
Tom_P
October 16, 2024, 8:19pm
3
looks like this topic is similar to
Working and teaching a lot of SubDs in the last weeks.
I would love to see an interactive command, that allows to “beautify” a (partial) Edge Loop.
(maybe also Face Loop)
The command should allow and combine the following optoiins
equal distribute spacing / distances (make them all the same)
homogenous spacing (locally average the spacing - allowing small to big distances distributed linear / quadratic)
symmetry (automatic / set plane)
radiate (align to a circle - combined with above option…
and
I wrote a similar topic :
I think it s important to have several options (see topic) … it s more then distribute / equal space that s why the working title is “beautify edge loop”
BrianJ
(Brian James)
October 17, 2024, 12:15pm
4
Yes, and the request is filed https://mcneel.myjetbrains.com/youtrack/issue/RH-67818 . I’ll try and bump it again.
