Hey there! So i have this definition from @HS_Kim, i am trying to connect 9 spheres but the transitions are not clear somewhere as i wanted. I tried to play with the parameters but could not figure out what causing the problems. Any recommendations? Thanks in advance. ![]()
subdfuse.gh (17.6 KB)
I think this is a better workflow for what you try to achieve:
You’ll end up with a neat quad mesh that you then can convert to a subd, if needed.
subdfuse_2.gh (11.5 KB)
hi! yes it works better now, i understand. thank you!
