SubD Bevel interface
You really did a great job with implementing SubD in Rhino, it’s so great!
I have one question about the SubD bevel command. I can’t really figure out how the manual control works when inside the command. It seems the control is positioned at a random hidden/unmarked position somewhere along the bevel, really dfficult to control the bevel and if I don’t find where the control area is and right-click which normally is used to finish a command nothing happens but if I left click it makes the bevel.
Am I doing something wrong/miss something?
bevels are much easier to control when added in box mode
aha! testing ooh yes, a lot easier. Thanks. Would be nice if the control was on the mouse wheel or just up and down on the screen.
It also helps to disable osnaps.
