Having trouble with creases not working as expected in SubD
hi there … i’m trying to figure out why i can’t get this to work but after a couple of hours trying different quad structures i’m at a loss.
so what i want to achieve here is basically the green square with all crease edges being straight lines but for some reason the left edge wants to bulge out in a curve instead of being straight. i might just have tunnel vision but i can’t see how this quad structure is flawed.
the only way i can get it to work is by continuing the crease upward like so:
which is not really what i want for the model. would love to understand why this happens since i’m getting much better with quads/subds as i clean up my models and convert them from nurbs to subd but i stil have many things to understand about the inner workings … this being one of them :blush:
any ideas anyone ?
Can you post a model or a part of it?
dear @chris16
are you aware that there is a difference between creasing a SubD-Vertex and a SubD-Edge ?
left to right
  • no creases
  • creased edges
  • creased vertices and creased edges (3 of 4)
if you need more help, please post a file.
hope this helps - kind regards - tom
hey thx Tom for your quick reply … unfortunately i can’t post the file since it’s a production file of one of my guitars. i’ll try to cut out a piece and post it.
i am aware that you can crease vertexes and edges separately … sort of :joy: … meaning i don’t really understand yet why you’d do one or the other … guess i’ll have to read up on that but couldn’t really find anything on it in the docs or web.
EDIT … ok here’s a cutout of the model:
creaseDebug.3dm (3.1 MB)
Modeling strategies vary… I’m not such a big fan of creases and I’d suggest to use move the edges closer together where you want sharper edges. Or use the new sharp command in Rhino 8 WIP.
Also the corner in your model is not really a corner since it has 4 adjacent faces. A simple corner has 3 adjacent faces…
I’m not sure which of the edges should be creased, maybe you still need to post a full model.
creaseDebug.3dm (100.7 KB)
Here’s a second option which leads to a nicer corner, no matter which of the edges are creased:
creaseDebug_corner.3dm (93.2 KB)
ah yes of course … adding edges is agreat idea. i’m also not a fan of creases but for manufacturing sometimes i need a really crisp precise edge somewhere, in this case this is the junction of the guitar’s neck and body so a crisp edge is kinda mandatory. but really many thx, this got me ‘unstuck’ and i can now move on and experiment further instead of bangin my head against the wall :slight_smile:
i didn’t even know Rhino 8 WIP was available, that’s cool and diving into that is a perfect occupation for a sunday.
example:
000
hey thx, that’s also a great technique i hadn’t thought about
