Hi everyone, I’m stuck with this problem in rhinoscript.
I need to import some stl files into rhino and put each on a layer with the name o the folder they are in.
I have a main folder with subfoldes with stl files in them.
This is what I have so far:
Call BatchImportGen
Sub BatchImportGen()
' Allow the user to interactively pick a folder
Dim strFolder
strFolder = Rhino.BrowseForFolder(strOldFolder, "Select folder to process", "Batch Import")
If VarType(strFolder) <> vbString Then
Exit Sub
Else strOldFolder = strFolder
End If
' Create a file system object
Dim objFSO
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Get a folder object based on the selected folder
Dim objFolder
Set objFolder = objFSO.GetFolder(strFolder)
' Process the folder
Call RecurseFolder(objFolder)
' Release the objects
Set objFolder = Nothing
Set objFSO = Nothing
End Sub
Sub RecurseFolder(objFolder)
Dim objFile, oSubFolder
' Process each file in the folder
For Each objFile In objFolder.Files
Call ProcessFolder(objFSO,objFolder)
Next
'Process Each subfolder In this folder
For Each oSubFolder In objFolder.SubFolders
Call RecurseFolder(oSubFolder)
Next
End Sub
' ProcessFile
Sub ProcessFolder(objFSO,objFolder)
' Import all files in the selecte subfolder
Dim objFile,strOpen,arrLCO,strSubFolder
strOpen = LCase(objFile.Path)
Call Rhino.Command ("_NoEcho _-Import "&chr(34)&strOpen&chr(34)&" _Enter")
arrLCO=Rhino.LastCreatedObjects(False)
strSubFolder = oSubFolder.Name
rhino.AddLayer(strSubFolder)
Rhino.ObjectLayer arrLCO,strSubFolder
Next
It works and imports every STL from each subfolder.
Where I’m stuck is to get the Subfolder name to create a layer.
Can someone give me a hand in this.
Thanks everyone
