I have several STL files that I sometime need to read into Rhino and I don’t want to do it manually.
How can I supply a file name to the import command in vbscript it will do it automatically.
Thanks
Thanks
Hi Gideon - use
Rhino.Command ("_-Import " & “Full path to file”)
Does that do what you want?
Hi Pascal
What I tried was not exactly as you suggest. I will try your recommendation.
Thank much
Hi Pascal
Tried your recommendation.
It looks like Import is having problems with blanks in a file/folder name.
Please see below:
This is my coding:
Call Main()
Sub Main()
Dim strFolder
strFolder = "D:\HW wb 422.stl"
Rhino.Command("_-Import " & strFolder)
End Sub
This is the result:
Command: _-Import
Name of the file to import ( Browse ): D:\HW
File D:\HW.3dm not found, unable to open
Please note that the command stops after the blank in the file name and it also assume that the file is a 3dm.
Any thoughts
Thanks
Perhaps try:
Rhino.Command("_-Import " & chr(34)&strFolder&chr(34))
–Mitch
Hi Mitch
That worked. Very strange that the quotes had to be in chr format.
Had to add “_Enter” to avoid having to hit enter when “STL Import Options” came up.
Thanks for your help
Hi Pascal,
Got it to work with some additional help. Please see my thread.
Thanks again for your help
Yep, Chr(34) - I should have mentioned that. You can add the Enter:
Rhino.Command("_-Import " & chr(34)&strFolder&chr(34) & " _Enter")
