Hi everyone, I just finished a script to import multiple files.
It was all working fine. I shut down rhino and started it again and now the script crashes Rhino.
I have no Ideia Way, I can’t see any mistakes but it has to be something.
Can anyone take a look please.
'Script written by FVA
'Script version 24 July 2013
Option Explicit
Private strOldFolder
If isEmpty(strOldFolder) Then
strOldFolder = Rhino.WorkingFolder
End If
Call BatchImportGen
Sub BatchImportGen()
' Allow the user to interactively pick a folder
Dim strFolder
strFolder = Rhino.BrowseForFolder(strOldFolder, "Select folder to process", "Batch Import")
If VarType(strFolder) <> vbString Then
Exit Sub
Else strOldFolder = strFolder
End If
' Create a file system object
Dim objFSO
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Get a folder object based on the selected folder
Dim objFolder
Set objFolder = objFSO.GetFolder(strFolder)
' Process the folder
Call RecurseFolder(objFolder,objFSO)
' Release the objects
Set objFolder = Nothing
Set objFSO = Nothing
End Sub
Sub RecurseFolder(objFolder,objFSO)
Dim objFile, oSubFolder
' Process each file in the folder
For Each objFile In objFolder.Files
Call ProcessFile(objFSO,objFolder,oSubFolder)
Next
'Process Each subfolder In this folder
For Each oSubFolder In objFolder.SubFolders
Next
End Sub
' ProcessFile
Sub ProcessFile(objFSO,objFolder,oSubFolder)
' Import all files in the selecte subfolder
Dim objFile,strOpen,arrLCO,strSubFolder, sail
strOpen = LCase(objFile.Path)
Call Rhino.Command ("_NoEcho _-Import "&chr(34)&strOpen&chr(34)&" _Enter")
arrLCO=Rhino.LastCreatedObjects()
strSubFolder = objFolder.Name
rhino.AddLayer(strSubFolder)
Rhino.ObjectLayer arrLCO,strSubFolder
Next
End Sub
