I’ve been trying to create a solid all day by joining a cylinder a cone and a curve network together. About 3 goes out of 12 have been successful, but it’s not reliable enough to make the whole model. I don’t know whether it’s my tolerances that are out, or if trying to join a curve network to a cone is asking for trouble or even whether there’s a bug in Rhino Mac.
I’ve attached four models to show the steps.
Step 1 - move a cylinder a short distance away from a cone, connect it to the cone with a quarter ellipse
Now move a slightly eccentric cylinder to cut into the cone and produce a curve from the intersection
Step 2 - move the eccentric cone away, leaving the intersection curve and add two straight lines connecting the curve to the edge of the cylinder (for some reason I can’t get a third straight line to connect to the obvious place - it just won’t locate a connecting handle at the right point)
Step 3 - select the two straight lines, the quarter ellipse, the intersection curve and the circle at the end of the cylinder to create a curve network. This seems OK
Step 4 - First join the cylinder to the curve network by doing Edit, Explode then Edit, Join
Then try to create a solid by selecting the joined object and the cone and doing Solid, Create Solid
The message looks ok, but what actually happens is that the cylinder and the curve network get dropped.
Systems details are below and I’ll attach the models (if I can work out how to - UPDATE Problem_Step2.3dm (51.7 KB)think I’ve managed to upload them)
Details from about box are
Software informationProblem_Step1.3dm (60.1 KB)
Software versions
Rhinoceros version: 5.1 (5B161)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
OS X version: Version 10.9.5 (Build 13F1134)
Plug-ins
None
Third party kernel extensions
com.deterministicnetworks.driver.dniregistry (1.0.7)
com.deterministicnetworks.driver.dne (1.0.18)
com.citrix.driver.net6im (1.1.9)
com.Cycling74.driver.Soundflower (1.6.6)
com.sophos.nke.swi (9.4.50)
com.sophos.kext.sav (9.4.50)
Hardware information
Computer hardware
Hardware model: MacBookPro8,1
Processor: Intel Core i5-2415M CPU @ 2.30GHz
Memory: 8 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel HD Graphics 3000 512 MB
Memory: 512 MB
Screen size: 1920 x 1080
Displays: S22C350 (102dpi 1x)
USB devices
Apple Computer, Inc.: IR Receiver
Apple Inc.: Bluetooth USB Host Controller
Canon: CanoScan
Mitsumi Electric: Apple Optical USB Mouse
Apple Inc.: Apple Keyboard
Wacom Co.,Ltd.: Intuos PS
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-8.24.17
Render version: 2.1
Shading language: 1.20
Maximum texture size: 8192 x 8192
Z-buffer depth: 24 bits
Maximum viewport size: 8192 x 8192
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: NoneProblem_Step3.3dm (67.1 KB)Problem_Step2.3dm (51.7 KB)Problem_Step4.3dm (68.3 KB)
