I was able to take the structural framing and do the Add Analytical Element with no issues but when i tried to do the same thing with structural columns i got the following issue with all of the elements
“Model element is not supported for creating an analytical element. {2462273}”
Working in RIR 2026. Its not urgent just confusing
@cflynn What does the warning say? I believe you have extract the location line of the structural column and then use that to create the Analytical Elements.
The warning says this ““Model element is not supported for creating an analytical element. {2462273}”” odd that the framing doesnt require that, you just plug those elements into the Add Analytical Element component you you’re good to go.
