Good morning,
I would like to know if there is a possibility to enable in GH the analytical model from RiR. When I unpinned the geometry generated with RiR the analytical model is disabled.
Thanks!
Good morning,
Thanks!
I did this model and at the bottom turned in the analytical model for existing objects.
https://www.rhino3d.com/inside/revit/1.0/discover/analytical-model-manipulation
Thank you very much Scott. It works perfectly.
Do you know how can I select the Analytical elements in GH? I would like to add a comment in the Analytical Beam, but I do not find the way to do it
