Struct Triangle3d for triangle incircle
Hi all,
I’m trying to use the Triangle3d structure but it seems to be non-existent in Rhino.Geometry. Is it deprecated? I’m using Rhino 6 btw.
The reason I want to use the struct is because I need to calculate the incircles of triangular faces in a mesh for determining aspect ratios, and I think that the Circumcircle property is that, but I might be wrong.
So any alternative to Triangle3d to calculate the incircle or aspect ratios is also welcome.
Thanks in advance,
Eduardo
Hi @castroecosta,
It appears the struct is only available in Rhino 7 and newer versions.
– Dale
triangle ratio.gh (10.5 KB)
For out circle we can use rhino circle class, for incircle radius > Incircle and excircles of a triangle - Wikipedia
  public double TriangleRatio(Rhino.Geometry.Point3d A, Rhino.Geometry.Point3d B, Rhino.Geometry.Point3d C){
    Rhino.Geometry.Circle cir;
    List < Rhino.Geometry.Point3d > pts = new List<Rhino.Geometry.Point3d>{A, B, C};
    Rhino.Geometry.Circle.TryFitCircleToPoints(pts, out cir);
    double R = cir.Radius;
    double a = A.DistanceTo(B);
    double b = B.DistanceTo(C);
    double c = C.DistanceTo(A);
    double s = (a + b + c) / 2;
    double r = Math.Sqrt((((s - a) * (s - b) * (s - c)) / s));
    return (2 * r) / R;
There’s also
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Circle__ctor_3.htm
for circle through 3 points
Thanks everyone for such quick feedback!
I ended up using a formula for aspect ratio
AR = a * b * c / ((b + c - a) * (c + a - b) * (a + b - c))
that I found here (see bottom) (c++ - Aspect ratio of a triangle of a meshed surface - Stack Overflow) and seems to be doing the job.
But I’ll definitely revert to your suggestions in case it fails down the line.
Thanks again, Eduardo
