Strech view tool
Hello, I wonder if in Rhino 7 is possible to strech a view for analysing a curve or surface.
I tried to search it in the set view palette, but I didn’t find anything for that. Maybe in another palette?
Thank you in advance.
Hi Jordi -
The viewport scaling in the x- or y-direction in the settings for the display mode might be of help here.
Those settings can be found in Rhino Options > View > Display Modes > (_your mode_) > Other
@pascal provided some quicky doodle script in a very recent thread as below, unfortunately it does not work with perspective if that is needed since the scaling only applies to orthogonal views.
Hi Wim,thank you for your answer, but I don’t follow you very well, how do you scale the viewport in x or y before saving it in the display mode tab?
Thank you Encephalon!
Hi -
I’m not sure what you mean by this part.
You change the setting in the display mode that you are using and the view updates when you exit that dialog box.
