Hi, I’m seeing this strange displacement on the surfaces of the rendered view of a block object, only since I’ve applied a new material to it. There is not a problem with the material, it is used many other places in the model with no issue. It also was not a problem on this poly surface before, when I had a different material.
What is really strange is that the surface looks just fine when I’m in the block edit mode:
But then when I leave block edit mode, the surfaces of these panels go all wrong:
Again, this is the same instance of material as all the wood panels around this, so doesn’t make sense why this one polysurface would react differently.
Any help is appreciated
