Hello. I notice a strange behavior when i try to split an image in rhino 7. The texture repeated in splitted parts.
In rhino 6 works as expected.
Both versions are up to date.
Yep there are a few bugs in Picture in V7 - I don’t think they have been fixed yet.
OK i found what cause the problem but i don’t know how to resolve it.
I have visualarq installed in rhino 7. I installed it in rhino 6 to check if this cause the problem and now i have the same behavior in rhino 6.
Hmm, that’s odd, I reported a different bug that was not related to VisualARQ…
@ar00302 Can you post a file with the image (before the split) to test?
@fsalla Do you know anything about this?
I experienced a similar problem in the past, where the problem only happened when the split was made from the Top viewport. But from the Perspective viewport it was working fine (or perhaps it was the other way around).
However, this seems to be fixed in Rhino 7 or in the recent updates of Rhino 6 because I can’t reproduce it anymore.
In any case, VisualARQ is not related to this issue.
Cité de l’Océan et du Surf_R6.3dm (2.6 MB)
System_info.txt (2.6 KB)
The images are not present in the file. You will need to re-save it with save textures checked… then re-upload it.
sorry, my mistake
Cité de l’Océan et du Surf_R6.3dm (3.6 MB)
Hi there, could you solve the problem?
