If you open a stl cad file in rhino called “examplesize6.25.stl” in Rhino. And then you click the SAVE bottom , The text in the FILE NAME will read “example6”
Why does the “.25” from the name get cut off and is there a way to avoid this from getting cutoff.
Also if you are in the SAVE screen and have .3dm and the file type and you type “examplesize6.25.stl” but then if you change the file type to .stl , the text changes to “example6”
Hi Roger - presumably the dot indicating a file extension is messing it up when offering the default name - it strips anytghing after a “.” as being a file extension.
Hi Roger - it looks like Save does this when non-3dm files are opened and Save must ask for a name. With 3dm files, of course Save does not ask any questions.
Hi Rioger - it is very hard to say - in V7, we are pretty much wrapping up development so it is less lilely to make it to a service release. If it can be tuned up - which seems very possible, but I can’t promise 'cause I don’t really know - it would liklely be in V8.
