Can it be done with save small, through a macro.
Probably not a good idea since so much information is lost in creating the STL mesh.
Best practices suggests:
- Check the NURBS model to make sure is closed and solid
- Run the Mesh command to create a mesh from the NURBS model
- Check the mesh to make sure it is ‘good’, and in the rare case where it has problems, fix them.
- Export the checked good mesh to STL.
