Hello!
I work with scenography for events and trade show booth building and usually the computers I work on are very low specs computers and even simple definitions may take a long time to execute. To avoid lags and unnecessary lockups, I don´t use sliders as they usually take a long time to change some parts of the definitions.
I wonder if there is any way to make grasshopper execute the definitions with some planned steps. To make my question simpler, let´s imagine the following…
A simple furniture, made with metal tubes, but the space between the tubes we will install a mesh. That mesh and metal structure may vary from case to case. So, this definition, I would need to make a definition that would have the following steps:
- Define the overall size of the structure. (width, depth and height)
- Define the metal type and size (round or square tube width and wall thickness)
- Define the mesh type for the finished types
- Bake the results
The problem I face usually is that when I am defining the size of the structure the mesh is always being calculated and this sometimes take a long time to finish.
Is there any way to pause a part of the definition to run until the first part is totally finished?
