A customer reported (and I’ve been able to verify with the macOS version of Rhino 7) that STEP faces in the format open shell / shell based surface model / manifold surface shape representation imports each face as an independent surface, whereas STEP faces set up as closed shell / manifold solid brep / advanced brep shape representation are created as a solid. (In both cases this is with the “join surfaces” option turned off.)
Is this the intended behavior? Is there a way to format open shell faces so that they automatically import as one object into Rhino 3D? I don’t seem to have any difficultly using openNURBS to create the exact equivalent of the STEP open shell object as a single object in a 3dm file and then load it into Rhino that way…
