Startup commands in scheme?
Good afternoon,
Just wondering if something changed recently with startup commands in the registry? I have a startup_commands registry string in:
HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\6.0\Scheme: MyScheme\Options\GeneralSettings
that does not seem to work anymore on the most recent update (6.5.18149.14421, 5/29/2018). Is there a new method of setting up a startup command for a scheme in Rhino 6? It was working just a few days ago.
Thanks,
Hi @AndrewZ,
Rhino 6 does not store settings and preferences in the Windows Registry. Rather, it saves them to XML files.
%APPDATA%\McNeel\Rhinoceros\6.0\settings
– Dale
RH-46475 Help: Description of the Scheme parameter is out of date
Created this YT issue for updating the help topic.
http://docs.mcneel.com/rhino/6/help/en-us/index.htm#information/startingrhino.htm
No, only the location for saving the data is changed.
Thanks for clarifying that @KelvinC. I am working on migrating a project from Rhino 5 to Rhino 6, and in my Rhino 5 project I used that startup_commands reg key to run a command automatically when starting Rhino with my scheme. How would you recommend achieving the same result in Rhino 6?
Hi @AndrewZ,
Of course, the easiest way is to just copy-paste the startup command (Tools > Options > General) between Rhino 5 and Rhino 6. If you’re trying automate this, then you’ll need to edit the setting XML file yourself.
– Dale
OptionsExport in v5 and OptionsImport in v6 also work for the common settings in the two versions.
