Wrecked my ini file V5 64 bit
Is there a way to reset Rhino V5 64 bit to original settings?
I allready uninstalled 32 and 64 bit version, installed it again but the settings still are wrecked.
Hi Frits,
Yes - you can delete your Rhino scheme and Rhino will be back to the setting it has when it was first installed but you will need to edit your Windows registry
  1. Close Rhino.
  2. Run the Windows Regedit command.
  3. Navigate to HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\5.0x64
  4. Right click Scheme: Default, and Delete.
  5. Reopen Rhino and the default schedule will be recreated.
Let us know if this works for you.
Sincerely,
Mary Ann Fugier
McNeel Technical Support
:fireworks::tada::clap:
Mary Ann, you are great!!! thanks from a very happy person from Holland!
I deleted not the whole scheme but the ones I wanted to change and it worked very well,
Thanks again
