Steps taken:
- Used
OptionsExport
to export custom options. - Uninstalled RH6 BETA.
- Installed RH6.0 and RH WIP.
- Used
OptionsImport
to read portions of the custom options.
Observations:
- Only the first entry in
Rhino Options > General > Command Lists > Run these commands every time Rhino starts
is read. - When opening the
INI
file in Notepad, I find a singleStartupCommands=*
entry. - The following lines in the file are settings with the
KEY=VALUE
format. - The last lines before the next heading (
[Options\Grid]
) contain the remaining cmds but not formatted withStartupCommands=*
Ref: RH-43692
(I’ve put this down as ‘major’)
