I have an airplane interior and the Rhino renderer needs several minutes to start (>~10min). Also started per V-Ray is quite slow (maybe 3…5min). Could it be possible to speed up the process?
-Micha
-Micha
If you are using unwrapped texture mapping and/or procedural textures then start up may take time due to baking of textures.
If that is not the case I’d like to receive the model for investigation. You can do that directly with me using rhino3d.com/upload?to=nathan@mcneel.com
