I need help doing something similar like this but only 1 tessellation and not so many and it should be parametric like can change the size and number of sides to fit in any form of curve surface thanks!
Assigned to Grasshopper category.
So you want someone to realize your vision for you… Where did you get that? Nice animation.
You could use this as a mapping pattern for your target surface…
This looks good thank you so much? Do you think i can export them 1 by 1 and map it on a surface
