Standardization in triangular panels
hello all,
I am trying to learn more about optimization. Right now, in this geometry, I have maybe hundreds of different kinds of triangles. ı want to have more standardization. I used the K-means Clustering component. But as I understood, it does not change the shape by taking the average, just puts the elements into subgroups. I want to achieve this kind of geometry by repeating the same triangles. ıt does not important how many different types is going to be used. Only getting similar geometry by using a certain type of triangle is important.
I would appreciate it if you could help. Thank you in advance.
Hi! Attach your files please
Please use the search function and look for triangular paneling optimization. The topic has been discussed heavily.
21.10.2025.3dm (1.0 MB)
21.10.2025.gh (19.4 KB)
here you can see my files
Hi Öykü,
as Martin said, you can research this topic on the forum.
However, with a quick approach, you can reach the following result.
21.10.2025.gh (34.6 KB)
You can add more constraints, such as angle values. You need to adjust these values and choose the result that works for you.
Thank you so much. You made my day. I am so grateful :slight_smile:
