Standard Steel Beams
I’m wondering whether there is a plugin or script available that makes it easy to input standard steel beam sections (Australia, UK, European etc.) or even allow the user to define specific section properties such as I section, Channel, Purlins etc. for buildings etc.?
I’ve seen an old script from 2015 for Rhino 4 but doesn’t appear to work in Rhino 5.
Thanks!
Ben.
If you have that script you might want to post it and perhaps someone can check it for RH5 / 6.
Other than that, search for e.g. structural steel on www.food4rhino.com.
Here are a few that might be worth looking into:
http://www.food4rhino.com/app/karamba
Thanks very much,
I’ve attached the script.
Regards,
Ben.
steel.ini (3.5 KB)
steel.rvb (10.7 KB)
The script works well, well except for creating self-intersecting curves.
Just copy the steel.ini file to your rhino 5 system directory, drag and drop the rvb file onto an open rhino session and bath in the majesty.
C:\Program Files\Rhinoceros 5.0 (64-bit)\System
Does this script work in Rhino 6? I tried it did not. TQ
I get an error on line 357
– Rhino.AddStartupScript Rhino.LastLoadedScriptFile
Can someone port this to R6?
Thanks
Any luck importing any of those yet? Thanks
