I have a complex roof and I have a beam profiles which i need to send to Revit using Rhino inside Revit. One option is direct shape but I want the actual family of Revit itself aligned to the sweep planes defined by the use. However, Add Structural Beam component does not have a way to define the sweep plane for beams.
Could someone please guide me with this ? I have attached the image for the same. Please let me know
I want to provide sweep planes to RIR’s “Add Structural Beam” component to get the correct orientation of the beams which currently, I do not see in Revit GH toolbar. I do not want this to be direct shape. Also, the second image is where I tried to implement it but maybe I am doing something wrong.
I have attached the sample Grasshopper file with internalized data as well and also a Rhino file for recreating it. Also, I want a clean joint in Revit so I can make structural details in Revit like bolt design and also complex intersecting beams( 5 or 6 nodes).
I appreciate you sharing with me this. Yes, I would like to have the same effect also with the joints split at node intersection please. Could you share your GH workflow please?
The script which you shared does not have any planes is it computing from the simplified curve. Is there a way one can define custom planes or RIR computes that internally?
It is still not clear as using your logic the angles are different. Please see the screenshot
