Stairs with Glass Panel Railing
I am trying to replicate this stair in Visual Arq using glass panel railing.
I see that you can generate the traditional railings in Visual Arq, however, is it possible to specifically generate Glass Panel Railings?
Thanks.
Hi @MetDesignLab, Yes you can create a glass panel railing combining the Rail, Post and Baluster components.
If you check the VisualARQ templates, there are a couple of railing styles for glass panel railings. Take a look at how are they created to customize your own design:
If the existing parameters for creating new railing styles don’t meet your design expectations, you can always create them through a “Grasshopper style” (VisualARQ styles created from GH definitions)
This is cool tool! Can I save my own edits some how?
Hi Totti,
Yes, the changes you do on the object styles, as well as new ones you create are saved in your file. And you can also export them to a .val file (visualarq library file) and import them in other documents. Take a look at this page of the VisualARQ tutorial: https://www.visualarq.com/learn/video-tutorial/4-8-export-and-import-styles/
