I always wondered what does StackOverflow
means.
Does anyone have any suggestion how to fix the code below?
import clr
clr.AddReference("mscorlib")
import System
from System.Diagnostics import Process
""" Example"""
class P(System.Diagnostics.Process):
def __init__(self):
self.StartInfo.UseShellExecute = True
self.StartInfo.FileName = r"C:\Windows\System32\cmd.exe"
self.StartInfo.CreateNoWindow = False
self.standard_input = None
self.standard_output = None
self.standard_error = None
@property
def StandardInput(self):
return self.standard_input
@StandardInput.getter
@StandardInput.setter
def StandardInput(self, val):
self.standard_input = System.IO.StreamWriter(val)
def Start(self):
return self.Start()
p_instance = P()
p_instance.Start()
p_instance.StandardInput("dir")
Thanks in advance.
jdhill
October 17, 2019, 4:12pm
2
self.Start() calls self.Start()? Do you mean fix the design of the code, or find that problem?
ha
Thanks @jdhill . What should it be?
def Start(self):
return System.Diagnostics.Process.Start(self)
jdhill
October 17, 2019, 4:21pm
4
Can’t say I’ve done a whole lot with .NET python, nor with inheriting from Process … but maybe you are looking for super.Start().
As far as I understand super is the class my class is derived from.
Meaning:
super.Start() == System.Diagnostics.Process.Start()
Which is internal or whatever they call methods that are only called from an instance of the class in .net
Solution here seems to work, but how can I do this with my own class?
I’ll try "".format()
I’ve found super() in the context of Rhino/Ironpython to be strange.
Maybe helpful:
https://ironpython.net/documentation/dotnet/dotnet.html#calling-base-constructor
Also the syntax for using super in 2.7 is different than 3.+:
https://docs.python.org/2.7/library/functions.html#super
class C(B):
def method(self, arg):
super(C, self).method(arg)
weird
import clr
import System
pi = System.Diagnostics.ProcessStartInfo("CMD.exe")
pi.ArgumentList.Add("cd /")
pi.ArgumentList.Add("dir")
pi.ArgumentList.Add("cd Windows")
p = System.Diagnostics.Process(pi)
p.Start()
result:
but ProcessStartInfo
has a property ArgumentList
according to this:
https://docs.microsoft.com/en-us/dotnet/api/system.diagnostics.processstartinfo.argumentlist?view=netcore-3.0&viewFallbackFrom=netframework-4.8
Update:
Just noticed the link it has view=netcore-3.0&viewFallbackFrom=netframework-4.8
Is it possible that ArgumentList
was added in a version not yet supported by IronPython?
I have a little progress:
import clr
import System
class MyTestProcess:
def __init__(self):
p = Process()
p.StartInfo.UseShellExecute = False
p.StartInfo.RedirectStandardInput = True
p.StartInfo.RedirectStandardOutput = True
p.StartInfo.FileName = r"C:\Windows\System32\cmd.exe"
p.StartInfo.CreateNoWindow = False
p.Start()
#System.IO.StreamWriter wr = p.StandardInput
#System.IO.StreamReader rr = p.StandardOutput
#wr.Write("dir" + "\n")
#System.Console.WriteLine(rr.ReadToEnd())
#wr.Flush()
mp = MyTestProcess()
I need to figure out how to translate the commented part
(code taken from here )
jdhill
October 17, 2019, 5:48pm
12
Regarding the ArgumentList, the docs say that is supported on .NET Core & Standard 2.1, but 2.1 is not supported on .NET 4.8, let alone the .NET 4.0 that I see for the IronPython in my Rhino install. You may use ProcessStartInfo.Arguments instead.
I realized that is not what I need, I need to start CMD with commands and not some.exe -arg
which I understand ProcessStartInfo.Arguments is for.
my batch looks like this echo some command with arguments | cmd.exe
the “|” pipes the ‘some command with arguments’ into the process of cmd.exe.
I wish to implement this without having to create .bat ( .cmd) file
jdhill
October 17, 2019, 6:04pm
14
Not sure I understand without more context; I imagine you mean you are doing something like echo python --version | cmd.exe
yes, imagine this is the batch.
I want to get rid of this batch and launch similar from .net (preferably with python)
if you have more than one command currently I have to do:
batch 1:
echo start batch2 arg1 | cmd.exe
batch 2:
echo command arg1 arg2
in order to get all necessary inputs inside the same cmd.exe process.
I think I did it:
This is the answer:
import clr
import System
System.Diagnostics.Process.Start(r"C:\Windows\System32\cmd.exe", "/c cd c:/ & dir & cd windows & dir & pause")
This will probably work now with StartInfo.Arguments
jdhill
October 17, 2019, 6:52pm
17
fwiw, a couple other examples:
import subprocess
python_output = subprocess.check_output('C:\\Python27\\python.exe --version', stderr=subprocess.STDOUT)
print('python_output: {0}'.format(python_output))
cmdexe_output = subprocess.check_output('cmd.exe /c echo cmd.exe got {0}'.format(python_output))
print('cmdexe_output: {0}'.format(cmdexe_output))
And:
import clr
import System
from System.Diagnostics import *
def call(exe, args):
pi = ProcessStartInfo()
pi.UseShellExecute = False
pi.CreateNoWindow = True
pi.FileName = exe
pi.Arguments = args
pi.RedirectStandardError = True
pi.RedirectStandardOutput = True
p = Process.Start(pi)
p_out = p.StandardOutput
p_err = p.StandardError
p.WaitForExit()
return p_out.ReadToEnd(), p_err.ReadToEnd()
python_output = call('C:\\Python27\\python.exe', '--version')
cmdexe_output = call('cmd.exe', '/c echo cmd.exe got {0}'.format(python_output))
Thanks JD(@jdhill ),
The first example seems to gets stuck somehow but the second one is working.
TomTom
(Tom)
October 18, 2019, 1:06pm
19
Simplified: Whenever you allocate memory (directly or indirectly) you can do that on the heap or on the stack. A value type such as float, char or struct usually gets allocated on the stack by default, because they usually are small and need to be executed fast.
Objects which require much more space in memory such a class usually gets allocated on the heap, a bigger but slower piece of memory. Now a stack overflow usually appears when there is no memory left on your stack, usually this only happen nowadays if there is a memory leak somewhere (or if you are a victim of an attack)
Thanks @TomTom ,
I am still not quite sure what ‘heap’ and ‘stack’ are. At first I thought both are like two lists. One containing the variable names and the other containing the values. Reading your answer makes me understand I am dead wrong.
TomTom
(Tom)
October 18, 2019, 5:12pm
21
its just memory in your RAM. They work differently but are doing the same.
