I have this working Py2 code with a GetPoint Custom class that makes use of dynamically setting a boolean value in the following line:
bln = clr.Reference[bool](True)
Used then in the rc = line:
for i, obj in enumerate(self.TargetObjects):
bbox = obj.Geometry.GetBoundingBox(True)
rc = self.picker.PickFrustumTest(bbox, bln)
if not rc: continue
I’ve added super for the overall class but cannot seem to get the clr method working for Py3.
This is the error I am dealing with:
No overload for method 'CLRModule.Reference{}' takes '1' arguments(<class 'bool'>)
I can remove the argument and just right it as:
bln = clr.Reference[bool]()
but this doesn’t execute the rest of the script correctly because the bool value gets funky or is being incorrectly set I guess.
Working Py2 Code:
import Rhino
import scriptcontext
import System
import clr
class MyGetPoint(Rhino.Input.Custom.GetPoint):
def __init__(self, objs):
self.TargetObjects = objs
self.ClosestIndex = -1
self.Color = Rhino.ApplicationSettings.AppearanceSettings.FeedbackColor
self.SetCommandPrompt("hover object for info")
self.SetCursor(Rhino.UI.CursorStyle.Default)
self.EnableObjectSnapCursors(False)
self.PermitElevatorMode(False)
self.EnableTransparentCommands(False)
self.PermitConstraintOptions(False)
self.PermitOrthoSnap(False)
self.AcceptString(False)
self.AcceptNumber(False, False)
self.EnableSnapToCurves(False)
self.AcceptNothing(False)
self.PermitObjectSnap(False)
self.picker = Rhino.Input.Custom.PickContext()
self.picker.PickStyle = Rhino.Input.Custom.PickStyle.PointPick
self.picker.PickMode = Rhino.Input.Custom.PickMode.Shaded
def GetClosestObjIndex(self, viewport, window_point):
try:
if not viewport: return
if not window_point: return
xform = viewport.GetPickTransform(window_point)
self.picker.SetPickTransform(xform)
bln = clr.Reference[System.Boolean](True)
if not rc: continue
if rc == True:
self.ClosestIndex = i
else:
except Exception as ex:
print(ex)
def OnMouseMove(self, e):
self.GetClosestObjIndex(e.Viewport, e.WindowPoint)
Rhino.Input.Custom.GetPoint.OnMouseMove(self, e)
def OnDynamicDraw(self, e):
try:
if self.ClosestIndex >= 0:
obj_guid = self.TargetObjects[self.ClosestIndex].Id.ToString()
obj_type = self.TargetObjects[self.ClosestIndex].ShortDescription(False)
obj_name = rs.ObjectName(obj_guid)
obj_name = obj_name if obj_name else "unnamed"
combined_text = r"Name: " + obj_name + "\nType: " + obj_type + "\nId: " + obj_guid
text = combined_text.lower()
e.Display.Draw2dText(text, self.Color, e.CurrentPoint, True, 16)
print(ex)
def DoSomething():
scriptcontext.doc.Objects.UnselectAll()
scriptcontext.doc.Views.Redraw()
obj_ids = rs.ObjectsByType(0, False, 3)
if not obj_ids: return
objs = [rs.coercerhinoobject(obj_id) for obj_id in obj_ids]
gp = MyGetPoint(objs)
get_rc = gp.Get()
if get_rc == Rhino.Input.GetResult.Point:
if gp.ClosestIndex >= 0:
rs.SelectObject(obj_ids[gp.ClosestIndex])
else:
print("Nothing selected")
DoSomething()
Attempt to update for Py3 Code:
import Rhino
import clr
super().__init__()
self.SetCommandPrompt("Select object")
try:
if not viewport:
return
return
bln = clr.Reference[bool]() # Create a reference with an initial value
Rhino.RhinoApp.WriteLine(f"Testing object {i}: rc = {rc}, bln.Value = {bln.Value}") # Debugging print
if rc and bln.Value:
Rhino.RhinoApp.WriteLine(str(rc))
Rhino.RhinoApp.WriteLine(str(self.ClosestIndex))
break
else:
print(ex)
try:
obj_id = self.TargetObjects[self.ClosestIndex].Id
obj_name = rs.ObjectName(obj_id)
if not obj_name:
obj_name = "Unnamed"
obj_guid = obj_id.ToString()
text = f"Name: {obj_name}\nType: {obj_type}\nId: {obj_guid}"
e.Display.Draw2dText(text, self.Color, e.CurrentPoint, True, 20)
print(ex)
def DoSomething():
if not obj_ids:
return
get_rc = gp.Get()
else:
DoSomething()
Has anyone come across this in Python 3 that could lend some pointers?
Thank you all for your help!
