Hi all.
I’m trying to flow from srf0 to srf1 a set of points on srf0. Something is not working. Morph is not valid and if i create the points they are on srf0 .
Here there is a command and a file 3dm rhino6 you can try.
test.cs (5.6 KB)
test_morph.3dm (88.1 KB)
Hi @gianfranco74,
I have not run your code. But at first glance, this:
var pt0 = srf0.PointAt(srf0.Domain(0).Min,srf0.Domain(1).Min);
var pt1 = srf1.PointAt(srf1.Domain(0).Min,srf1.Domain(1).Min);
var pt_2d_0 = new Rhino.Geometry.Point2d(pt0);
var pt_2d_1 = new Rhino.Geometry.Point2d(pt1);
should be this:
srf0.Domain(0).Min,
srf0.Domain(1).Min
srf1.Domain(0).Min,
srf1.Domain(1).Min
Does this help?
– Dale
Thank you Dale, it is working.
