Hello Guys,
I have created a bridge using the loft component and now I am trying to split solid into equal elements, but for now unsuccessfully (attachment 1 - blue)
I also added a grey bridge which was created using polybeam component, but in this way sections are not perpendicular to curve. To sum up I want to divide blue solid and receive smaller solids as you can see in the next picture.
I would like to warn that every component that I found on this forum did not work.
Does anyone know how to do it? Any tips will be appreciated.
P.S. I have also a small problem, I can not figure out why in Grasshopper appears: “1. System. Exception: Error when deleting and inserting ShapeItem: The Brep geometry already exists”?
I hope that somebody knows how to fix it. It is really annoying…
Best regards!
I also attached a part of the bridge in Tekla view which I would like to split by vertical plane.
