Split Surface Panels - Need urgent help
Hi all !
I need urgent help. Red lines represent panels on rhino surface. How can I get each panel as a surface extracted from 2d lines somehow? File created by someone else and this is just a part of the huge model …
Any idea ?
file link:
panels.zip (189.2 KB)
Does the Split command do what you need?
Have a look at Paneling Tools
https://wiki.mcneel.com/labs/panelingtools
@Lorenco_Vidaic
Command: Split
Select objects to split ( Point Isocurve EdgeLoop ): selsrf
2 surfaces added to selection.
Select objects to split. Press Enter when done ( Point Isocurve EdgeLoop )
Select cutting objects ( Shrink=No ): Shrink=Yes
Select cutting objects. Press Enter when done ( Shrink=Yes ): selcrv
88 curves added to selection.
Select cutting objects. Press Enter when done. Press Enter when done ( Shrink=Yes )
Splitting… Press Esc to cancel
2 surfaces split into 482 pieces.
Creating meshes… Press Esc to cancel
