I want to split the any given polysurface into halves using a plane in grasshopper. I am new to this software.
My main aim is to get contours only on outside and only 180 degrees. This is for cutting tool path for milling.
thank-you.
@Toliakuldeep1998, you need to internalise your data, in your case into the mesh geometry component, before posting your file here. Otherwise, nobody is going to be able to inspect your geometry.
