Split list with two or more columns into one list
Hello!
I’m currently facing a challenge in Grasshopper: I have a list with four columns and would like to split it into separate lists, each with only one column. The data comes from a database that I’ve imported into Grasshopper for data analysis using Python.
Unfortunately, I can’t split the list using the existing components because the column entries lack indices. Does anyone have a solution? In theory, I could rewrite my Python code, but for data analysis, it’s advantageous to have all the data in Grasshopper first.
Thanks in advance.
I would use something like this:
in the Find input panel for the Replace Text you can put the exact spacer you have between your data
in case you also have leading spaces, I’d go through a Text Trim first:
perfect! Thanks :slightly_smiling_face:
at the very end you’ll need a flip matrix to get your data tree organized by column :+1:
