Dear All,
I need split data to two columns with input as below.
Please help me to solve it.
Thanks
âText Splitâ will return nine branches of two items each. âFlip Matrixâ will convert that data tree into two branches of nine items each, corresponding to your two columns. I have no idea how you want to present them as two actual columns in Grasshopper/Rhino?
Posting code that contains nothing more than the panel in your image would be WAY BETTER that the image alone. Instead of the text explanation above, I would have replied with working code.
Please see my excel and grasshopper file
<a class=âattachmentâtest.rar (19.7 KB)
Nha pho 6x14_V13.rar (81.9 KB)
Thanks you so much
I canât handle â.rarâ files.
Please check file attachment
I using LunchBox Component
There is no attachment. I donât want an Excel file either. I donât want to install LunchBox to get an Excel file reader. From the second image you posted, this is about much more than splitting a list of numbers. I donât know what to say anymore⌠Time to take a long break from the Grasshopper forum I guess.
See this:
Please check my file attachments
test.rar (19.7 KB)
LunchBox extension can download here
Hi @duchoabn, the problem is not that itâs impossible to install a plug-in like Lunchbox, but rather that itâs a lot of work that seems irrelevant considering the scope of the question.
Your original question only mentioned converting a collection of text in the form âA; Bâ into two lists of numbers (one with all the Aâs, the other with all the Bâs). This involves neither LunchBox nor Excel, itâs just vanilla Grasshopper.
@Joseph_Osterâs answer is basically correct, you need to use Text Split and then Flip Matrix to achieve what you want. Is that not the correct answer? If so, can you rephrase the question?
If you insert Text parameters between your ExcelRead components and your Panels, then internalize
the data in those text parameters you can remove everything to the left of them, making your file way simpler to deal with. Careful! Do not save and overwrite your actual file after you remove those objects.
This will allow us all to deal with your data without the need to install plugins, install Excel and or download xl
s files.
It is not possible to name objects in Grasshopper. You can draw text in the viewports at a specific location, but geometry in Grasshopper doesnât have layers, or names, or colours, or other attributes associated with it.
Furthermore I do not understand how two numbers can encode both the start and the end of a line segment. 71; 78
could be interpreted to mean an (x,y)
coordinate, but for a line you need two coordinates. What am I missing?
Ah I think I got it. The 77; 78
refer to the index of the points in the first panel, right?
If you had posted a simple GH file in the first place, uncompressed with RAR, with your list of points internalized, you would have your answer by now. No need for an Excel file or LunchBox plugin to read it or a RAR utility to open your files.
Hi David
It oke, I want create line from data with point coordinates, and point name. I think probably using script?
See if the attached helps. Instead of creating lines I use the Polyline component, it means you do not have to flip your data matrix.
data parsing.gh (24.6 KB)
Hi David
Points not random, need create from order (point start,point end) and point coordinate data, point name
