split fail.3dm (112.1 KB)
@geemix I think this is working as designed. If you have planar curves that are not on the surface, they get projected in both directions to find an intersection with the surface.
On the other hand, if you first pull these curves to the surface and then run split, you will get the result you are after.
that makes sense.. thanks @Gijs
