Hello everyone! I was wondering if anyone knows how to do solid patterns on a sphere? I’ve tried squashing a sphere combing flowing with the surface(the way I normally would do if I want some patterns on a cylinder ), but the problem is the squashed surface of a sphere is still quite curvy. which is hard to know how to draw the patterns as I wish…
you can use FlowAlongSrf with both base a target surfaces revolved.
sorry, not sure what you meant…please can you explain it with a bit more steps maybe?thank you very much!
Hi, thanks for the reply, but how to project the pattern on a sphere accurately?
In the attached model i have created two surfaces:
- A sphere with the ends removed for clarity
- A surface of similar proportions
I have created pattern on surface 1, and by using the FlowAlongSrf command i was able to flow the pattern onto surface 2 like this
Inputs are attached for your reference
flow.3dm (1.8 MB)
You must pay careful attention to the orientation and UV space of both surfaces. if they don’t match, you’ll get strange results
thanks so much for the detailed tutorial! it really helps! Is this method also able to create a ball like the photo attached? thanks!
No you’ll probably need to dive into this thread to understand your options for that
Oh, grasshopper…thought I could have avoided that hahaha! because I have no idea how it works…but thank you so much! you must be a tutor of some kind, really appreciate it!
Takes time to learn but once you got it you increase the number of variations you can make with a just a module tweak. Even if it does take time to learn, the benefits are amazing… Im not a CAD user but GH enables me to do it (not always right but usually quickly and with lots more features than I expected.) Depends on the usage i guess.
