SOS : Reverse engineering - extract
After some measurement on a new project, i need to make a kind of reverse engineering. I work on Metrolog X4 actually but this software doesn’t for this task. In this way, i downloaded Rhino 6 … and now i need your help! :sweat_smile:
Just to know, points were measured on a little cylinder and i need to create on iges from this. I don’t need a very high accuracy, it’s just to see a visual deviation on another measurement. At this time, i only have a points file that i imported in Rhino 6.
Thanks in advance for your tips ! :blush:
Best regards,
Julien.
Give the PointDeviation command a try. I use it all the time for reverse engineering from scan data.
Try our plugin Mesh2Surface. It is designed to do exactly these tasks. See mesh2surface.com
