Hi, I am doing some baby steps in the C# development world in Grasshopper using Rhino API.
Goal:
Sort by length a BrepCurveList
that I obtain after using Brep.Curves3D Property. The problem is that BrepCurveList
does not have a method to sort. I have been trying to cast a BrepCurveList
to a CurveList so I can use the method sort. So far all my tries have failed.
In the first component (See attached Rhino and GH files), I tried creating a simple list:
edges = _Brep.Curves3D;
List<Curve> Test1 = new List<Curve>();
Test1 = _Brep.Curves3D;
// Get the dimension of a curve
int listLength = _Brep.Curves3D.Count; // This line finds the length of the list to be analyze on the for loop
loopLength = listLength;
Rhino.Collections.RhinoList <double> curveLength = new Rhino.Collections.RhinoList<double>();
for (int i = 0; i < listLength; i++)
double lengthOfCurve = _Brep.Curves3D[i].GetLength();
curveLength.Add(lengthOfCurve);
length_ = curveLength;
In this case I get:
- Error (CS0029): Cannot implicitly convert type ‘Rhino.Geometry.Collections.BrepCurveList’ to ‘System.Collections.Generic.List<Rhino.Geometry.Curve>’ (line 60)
In the second component, I tried as well using RhinoList :
// Get the edges of the solid
Rhino.Collections.RhinoList<Curve> Test1 = new Rhino.Collections.RhinoList<Curve>();
// Sort by length
In this second case I get:
- Error (CS0029): Cannot implicitly convert type ‘Rhino.Geometry.Collections.BrepCurveList’ to ‘Rhino.Collections.RhinoList<Rhino.Geometry.Curve>’ (line 60)
I am starting my journey in C# developing with Rhino so if anybody can point me in the right direction I will really appreciate it.
Regards
SortUsingCSharpRhino.3dm (21.8 KB)
SortUsingCSharpRhino.gh (4.6 KB)
