I’m trying to script ‘Sort,’ but it’s not working, what am I doing wrong?
Thanks in advance for your response.
RhinoList.Sort Method (Double[])
20180916 00 sort values.gh (13.9 KB)
How to get only a ‘key’ from ‘sort’ and use the ‘key’ for sorting another list.
I know this will work, but not completely the way I wantend. With this the list has changed and I cannot retrieve the former list nor do I obtain a ‘key’ from it.
import Rhino as rc
listVa = x
listVa.sort()
print(listVa)
How it is meant to type the part below? I do not need the Namespace part?
I am trying to sort based on a key in another way. But, I cannot figure it out.
20180916 01 sort values.gh (12.5 KB)
Do you might know how to type a ‘key’ in the ‘sort method’ of Python, Python Rhino, and Python rhinoscriptsyntax?
Nice, thank you. Stil I am doing something wrong, do you know what I am doing wrong?
20180916 02 sort values.gh (12.0 KB)
Hi @ForestOwl,
I can’t really help to sort an entire list, but in case if you want to find indexes of min and max values and retrieve them, please have a look min_max_by_index.gh (7.6 KB)
So nice, thanks! I assume you mean with ‘define lambda’ the part of ‘pt: pt.DistanceTo(itemPt),’ am I understanding it right?
If so, I than understand that ‘lambda pt:’ including the colon are connected. So, ‘lambda and the colon’ are a thing? I confuse it with the = sign. Why could the colon not be an = sign?
So, ‘key = lambda pt:’ is a thing (which can be found ‘somewhere’ in ‘some manual,’ which I could not find)?
And, in that manual, are there other options shown like lambda?
I do not intend you to ask where I can find the manual, but only ‘how’ you could knew about that piece of magic.
Somehow, I cannot order other lists like the indices through ‘cpm’ with the same key. Do you know how that works?
20180916 05 sort values.gh (12.7 KB)
I think this,
SortedList=sorted(enumerate(Points), key=lambda (i,pt):pt.DistanceTo(itemPt))
(index,pt)=SortedList[0] #unpack
print index
or this.
SortedList=sorted(zip(range(len(Points)),Points), key=lambda (i,pt):pt.DistanceTo(itemPt))
print index
Tuple, Unpack tuple, enumerate and zip are all cool functinos that Pyhton provides.
ありがとう ! Arigatō!
Great Mikity, thank you!
Hmm… in this scenario I want to obtain the indices sorted by the sorted form of the Data list. I am not able to solve it. Do you know what I am doing wrong?
20181020 sort values 06.gh (7.6 KB)
Hi ForestOwl
You wrote less “lambda expressions” like this.
dist_listIxVa = [(i, v) for i, v in enumerate(dist_listVa)]
sorted_dist_listIxVa = sorted(dist_listIxVa, key = lambda float: dist_listVa[i])
Also, maybe avoid naming variables/functions float
, as this is one of the built-in Python functions (which you risk overwriting within the scope of your script).
Thank you for your responses.
sorted_dist_listIxVa = sorted(dist_listIxVa, key = lambda (i,v): dist_listVa[i])
I forgot the (i,v) after lambda too.
There are two mysterious things.
So, I guess this is what you intended to do…
sorted_dist_listIxVa = sorted(enumerate(dist_listVa), key = lambda (i,v): v)
Try it out.
Thank you! It worked and understand enumerate better know.
I was trying to script it like that with the v at the end. Now I finally understand how it works correctly. And understand Python better. Yes! Thanks!
