I am trying to sort a list of curves by its length. I am using the RhinoList.Sort Method (Double) method from the API but every time I assign it to a output variable I have this error: 1. Error (CS0029): Cannot implicitly convert type 'void' to 'object' (line 84)
private void RunScript(Brep _Brep, ref object edges, ref object centroid_, ref object length_, ref object sortedCurves)
// Get the edges of the solid
Rhino.Geometry.Collections.BrepCurveList curveBrepType = _Brep.Curves3D;
Rhino.Collections.RhinoList<Curve> curveCurveType = new Rhino.Collections.RhinoList<Curve>();
// This for loop helps to convert from a BrepCurveList to a CurveType list
for (int i = 0; i < _Brep.Curves3D.Count; i++)
curveCurveType.Add(curveBrepType[i]);
// Calculates teh center of the gravity of the brep
Rhino.Geometry.Point3d centroidBrep = new Rhino.Geometry.Point3d();
centroidBrep = VolumeMassProperties.Compute(_Brep).Centroid;
// Get the dimension of a curve
int listLength = curveBrepType.Count;
Rhino.Collections.RhinoList <double> curveLength = new Rhino.Collections.RhinoList<double>();
for (int i = 0; i < listLength; i++)
double lengthOfCurve = _Brep.Curves3D[i].GetLength();
curveLength.Add(lengthOfCurve);
// Sort by length
double[] curveLengthArray;
curveLengthArray = curveLength.ToArray();
sortedCurves = curveCurveType.Sort(curveLengthArray);
// Outputs
edges = curveBrepType;
centroid_ = centroidBrep;
length_ = curveLength;
I think I am following @DavidRutten advice based on his response for a similar question back in 2012 RhinoList Sort method question. What am I missing here
SortUsingCSharpRhino.3dm (21.8 KB)
SortUsingCSharpRhino.gh (5.9 KB)
