Something move or is this a Bug -Print
Has the “Print Multiple Layouts” moved, is there a method change, is it missing/bug?
This used to have a check box in the print setup “View and output scale” to check for multi page layouts prints.
This particular file has a 4 page drawing, all the individual pages are listed in the dropdown list
Am I missing something?
Thanks
I can see it!
running:
Version 8 SR11
(8.11.24233.1001, 2024-08-20)
Huh. not seeing that
Thanks for checking
currently running
Version 8 SR11
(8.11.24240.13481, 2024-08-27)
installed that earlier today in the hopes it would correct what was going on.
Hi Ken -
Please run the Rhino SystemInfo command and copy-paste the result here.
System Info below
Thanks
Rhino 8 SR11 2024-8-27 (Rhino 8, 8.11.24240.13481, Git hash:master @ b86341cde534cae6cae9bf38b1fc5368de3c5c8e)
License type: Commercial, build 2024-08-27
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-3-2021 (M-D-Y).
Primary OpenGL: NVIDIA RTX A3000 Laptop GPU (NVidia) Memory: 6GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\RhinoCAM 2024 for R8\RhinoArt1FileExporter For Rhino8.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Rhino 8\Plug-ins\RhinoCAM 2024 for R8\RhinoCAM 2024 For Rhino8.0.rhp “RhinoCAM 2024 - The cutting edge CAM plug-in for Rhino 8.0 from MecSoft Corporation”
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24240.13481
Make sure that you don’t have “Selected Objects Only” selected in the options below. When “Selected Objects Only” is active, many features aren’t available.
I just added an on screen message that now shows when this option is active to SR11.
Ahh
With that I found what was happening.
Print dialog starting up with Selected only (blank screen as nothing was selected)
Turn that off and I had a visible print but the option for multi page is not available.
If you Cancel out of the dialog window it just goes back to The previous setting only on the next attempt, and you are now in a loop.
You have to Close it, then reopen the print window the multi page option to be available.
Any chance that the multi print option can be unselectable as to its availability relative to selected objects option being check.
Rather that disappearing and having to reinitiate the print window?
Just noted you suggestion of the screen message
I’ll take another look at this. It may be better that we just don’t save the Selected Objects Only persistent state the next time the dialog opens. This way it doesn’t get unnoticed or misconfigured for a future session and will fix scenario where options are missing. I’ll see if I can get this into 8.11.
https://mcneel.myjetbrains.com/youtrack/issue/RH-83536/Dont-make-Selected-Objects-Only-persistent-on-print-dialog
I tried this in the past and had a pretty vocal set of users tell me how bad this idea is.
ok, we’ll mull this over and see what we can come up with then.
Only Selected Objects will no longer hide the multi page controls. I’ve just issued the change and it should show up in 8.12.
That would work, less of a mystery of where did it go.
Thanks
