this is mycode
private void ColumnLine_Click(object sender, EventArgs e)
m_ColumnCurveList.Clear();
m_CurveList.Clear();
Rhino.Input.Custom.GetObject go = new Rhino.Input.Custom.GetObject();
go.SetCommandPrompt("Select objects");
go.SubObjectSelect = false;
go.GroupSelect = true;
go.GetMultiple(1, 0);
go.GeometryFilter = Rhino.DocObjects.ObjectType.Curve;
int count = go.ObjectCount;
for (int i = 0; i < count; i++)
Rhino.DocObjects.ObjRef objref = go.Object(i);
Rhino.DocObjects.RhinoObject obj = objref.Object();
if (obj == null)
return;
Rhino.Geometry.Curve curve = objref.Curve();
m_CurveList.Add(curve);
try
foreach (Curve c in m_CurveList)
Point3d p1 = AreaMassProperties.Compute(c).Centroid;
Vector3d vec = Vector3d.ZAxis;
Line line = new Line(p1, vec, height);
doc.Objects.AddLine(line);
catch(Exception ex)
ex.ToString();
where is the error?
how can i show line?
