I’m getting really odd behavior with this one, what am I missing? This code will not give me the prompt for the second curve and ands the first twice to the document instead …
// TODO: start here modifying the behaviour of your command.
var go = new GetObject();
go.SetCommandPrompt("select curve1");
go.GeometryFilter = Rhino.DocObjects.ObjectType.Curve;
go.Get();
if (go.CommandResult() != Result.Success)
return Result.Failure;
Rhino.DocObjects.ObjRef obj = go.Object(0);
Curve c = obj.Curve();
doc.Objects.AddCurve(c);
var go2 = new GetObject();
go2.SetCommandPrompt("select curve2");
go2.GeometryFilter = Rhino.DocObjects.ObjectType.Curve;
go2.Get();
if (go2.CommandResult() != Result.Success)
Rhino.DocObjects.ObjRef obj2 = go2.Object(0);
Curve c2 = obj2.Curve();
doc.Objects.AddCurve(c2);
return Result.Success;
