import Rhino
import scriptcontext
import System
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
layer_names = rs.LayerNames()
layer_objects = list(layer for layer in scriptcontext.doc.Layers if not layer.IsDeleted)
for name in layer_names:
layer_obj = None
for layer_obj in layer_objects:
if layer_obj.FullPath == "MCS":
autoMCS = scriptcontext.doc.Objects.FindByLayer(layer_obj)
rs.ConvertCurveToPolyline (autoMCS[0], 0.1, 0.1, True, 1, 5)
Note that you are doing two for loops over layer data. First over layer names, then over layer objects. Do only one.
Also, you are using only the very first object of the potentially many you find. You probably can use the for...in idiom on autoMCS as well, make sure you convert each RhinoObject instead of just the one.
You probably meant to do the conversion to polyline inside the inner-most if so I edited your original post to have both the code block (tripple backtick), and the indented last line.
