It’s Rhino 6 expired evaluation. Here is the system information:
Rhino 6 SR25 2020-4-23 (Rhino 6, 6.25.20114.05271, Git hash:master @ f35d7ded15ec317635ced435d8df84327397038d)
License type: Evaluation, build 2020-04-23
License details: Stand-Alone
Expires on: 2020-05-28
Windows 10.0 SR0.0 or greater (Physical RAM: 7.8Gb)
Machine name: DESKTOP-MIS7AN1
Hybrid graphics system.
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 3-9-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 3-17-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 445.75
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2020
Driver Version: 26.21.14.4575
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.25.20114.5271
I also noticed something weird. When I enter a distance for the length of the extrusion (the example below used 15 degrees angle), lets say 30 mm, the preview shows 31 mm in one directions, and 29 mm if I flip the directions. No matter what’s the number, it’s always +1 or +1 depending on the direction.
The mouse tooltip itself shows 30 mm in both scenarios. Is that a bug or something wrong on my Rhino? The command ends and won’t build an extrusion as I get the error. However, if I extrude from a curve in the same position as the surface edge, it works.
I just updated my Windows and will download the latest drivers for everything, but I doubt that that’s the case. I have an old 3D connexion driver for SpacePilot discontinued device that does not work with newer Rhino 6. I will also uninstall it to check if it helps.
???) sing kumbaya!
Internet is soooo much easier and beautiful without disturbing ads. Also, the browser works faster this way and consumes less RAM and CPU power.
