Hi Mark, this layer organization is totally fine. Just take into account that if you want to place the VisualARQ objects into a specific layer, depending on the object type, you can also organize it from the Document Properties > VisualARQ > Layers.
All right. It seems quite useful to me to utilize the parent layers as the âvisibility toggleâ. That way I donât have to touch the list of component layers, because itâs becoming quite extensive.
In the Dutch methodology they make a distinction between exterior and interior walls for instance, and openings in these walls. I am following this method for the layer numbering and naming (there is a button for English version).
@ME_Mark @FORARK @Prehabitat just in case you havenât tried this new feature yet in VisualARQ 2, take a look at this video: https://youtu.be/rdX7I79qTTI
I have been working on the tutorial and I am having some diffilculties with wall joint types.
I donât know what Iâm doing wrong, but I canât get them to work. I have added two examples from the tutorial that donât give the results shown in the tutorial.
- the one with the rooflights: the upper one has the butt walljoint, but the sort order doesnât matter for the result.
the lower one a miter joint, and the sort order doesnât matter either for this result.
- the other shows the same problem
- And I donât get the right wall joints on the terrace level where a glass wall joins two 200 mm thick walls
Something different; I canât find the wall add solid command. The red concrete pieces should be joined with the curved wall.
Villa_Savoye-V2.3dm (15.2 MB)
Hi @ME_Mark,
Do you want this result:
In this case, the sort order will not affect, because the sort order is to change how the joint is solved, but this upper part of the wall is in a no-joint area, because the other wall is smaller. Iâve just used the control points to extend the wall.
The command is now generic and applicable to all VisualARQ elements, so it is now called vaAddSolids.
Regards,
Enric
Hi Enric,
Thank you for the first part, itâs working as it should. Donât know why I havenât tried that for my self in the first place
For the second part, I have used vaAddSolids on these walls, but I end up with several wall pieces that each contain the red parts. And in the video tutorial the red edge bars take over the color of the wall. In my case it doesnât.
